Difference between WRV200 and WRV210
Aug 26th, 2009
Dear Cisco
Can you tell me the main difference between WRV200 and WRV210.
Another question
The datasheet said that the WRV200 can run SSL VPN, is that rigth???
Cisco WRV200 Wireless-G VPN Router: RangeBooster
Secure Wireless Network Access for Small Offices
Highlights
• IPsec and SSL VPN connectivity on a single device
• Built-in 4-port 10/100 Fast Ethernet switch
• Multiple SSIDs and VLANs provide separate secure networks
• Simple, browser-based configuration
Figure 1. Cisco WRV200 Wireless-G VPN Router: RangeBooster
Te-Kai Liu Wed, 08/26/2009 - 09:41
  • Gold, 750 points or more
No, WRV210 does not support SSL VPN. It has 8MB of flash whereas WRV200 has only 4MB.
steenbroberg Fri, 08/28/2009 - 05:01
Do WRV200 support SSL. strange if yes a newer product do not
Highlights
David Carr Fri, 08/28/2009 - 08:18
  • Silver, 250 points or more
The only linksys small business router that supports ssl vpn is the rvl200.
David Carr Wed, 08/26/2009 - 07:13
As the two devices in comparision the advantage of wrv210 over wrv200 is that its Web UI supports multi language and it supports tftp based firmware upgrade. Regarding reliability both devices are the same.
