FWSM or ASA Configured for VRF
Answered Question
Aug 26th, 2009
I know that I firewall can pass VRF routed traffic, but can you actually configure a VRF instance on a ASA or FWSM?
thank you,
Kevin
Correct Answer by yagnesh_tel about 7 years 8 months ago
Kevin,
I think running FWSM/ASA with multiple context is same as having multiple VRFs in router. As using context you can get same functionality as vrf such as separate routing table, ACLs on the per context basis. So each context will act as separate standalone firewall.
Overall Rating: 5 (2 ratings)
Correct Answer
yagnesh_tel Wed, 08/26/2009 - 08:01
  • Silver, 250 points or more
Kevin,
ksvy_ksvy Wed, 08/26/2009 - 08:13
yagnesh, got it, that makes sense.
very good, thank you
