Reload Router / Switch LMS3.0.1
I recently deployed 70 switches 3750/3560 which also now requires an IOS upgrade. Can I schedule a reload using Cisco Works. I used Cisco Works to install the new IOS but the did not allow a reload at that time.
Joe Clarke
Sure. You can use Netconfig to schedule a reload. Create a new Netconfig job, and select the Reload template from the Tasks list. If your Netconfig protocol order specifies TFTP first, make sure you have the command:
snmp-server system-shutdown
Configured on your switches.
