ASA 5505 Easy VPN Client connect to UC520 problem
Aug 26th, 2009
I has tested 02 ASA5505 connect to each other via easyVPN and they seem to work (one as EasyVPN client in client mode and one as EasyVPN server)
But when connect ASA5505 VPN Client (in client mode) to UC520, which is EasyVPN server, the connection was established , but from ASA5505 client VPN, and LAN side of ASA5505, I unable to connect to LAN side of UC520
The other remote device such Cisco877, Cisco1841, and Cisco software VPN Client all are able to established easy VPN connections with this UC520, access to the LAN side (Data and VOIP VLAN...) of UC520
So it seem that there is a difference between Easy VPN Servers running on ASA5505 and UC520
Please advise how to fixed it
Thank you from Vietnam
