External Antenna Configuration IOS 12.3
Aug 26th, 2009
What is the effect if an external antenna is connected, but the radio configuration has the "External Antenna Configuration" disabled?
Is the radio functioning on the internal antenna only, or is the external antenna functioning without a set gain?
Anonymous (not verified) Tue, 09/01/2009 - 06:21
It seems like a bug CSCsl17857 C1231 running 12.3(8)JEC unable to set transmit/receive antenna options. C1231 running the IOS image 12.3(8)JEC will not display the options to change antenna to diversity, right or left. The command under dot11radio0 becomes unavailable. On the GUI of the AP only display the options for antenna transmit/receive but on change and apply, you will get the error "page cannot be display".
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
