NAC In-band problem
Aug 26th, 2009
I'm working about a solution in-band.
The topology is INET(untrust)-Router-CAS-SW_level3-CAM and servers(trust).
My problem is that the users in untrust network have access to the trust network, they don't authenticate and don't apply any rule. The end users are windows XP and don't exist any filter in the CAS.
mattwilsonuk Mon, 09/07/2009 - 06:00
For this you will need to create policies for the untrusted role.
Sounds like you have it allowing all traffic from untrusted to trusted.
Cheers
Matt
roicasjos Mon, 09/07/2009 - 07:48
No, the problem was fixed.
It was resolved to perform the software update.
thanks.
J.A.Roig
