uc520 antenna extension
Aug 26th, 2009
? how to extend the antenna built into the uc520?  i,e. RP-TNC (ReversePolarity-Threaded Neill-Concelman) extension cable..
what cable spec / authority / for:
RG (Radio Grade) coaxial cable.
50' extension, male to female RP-TNC connectors.
Saurabh Verma Mon, 08/31/2009 - 09:05
  • Silver, 250 points or more
Hi, you can hook up any RPTNC coax extension cable to attach to a remote antenna. Any of the: AIR-CABxxxLL-R listed below will work.
HTH,
Saurabh
Cisco Part   Number
Type of   Cable
Description
Loss at 2.4   GHz
Loss at 5.8   GHz
AIR-CAB005LL-N
Interconnect
5-ft low loss   cable, one straight N connector, one 90-degree N connector
0.5 dB
0.8 dB
AIR-CAB005LL-R
Interconnect
5-ft low loss   cable, one RP-TNC plug, one RP-TNC jack
0.5 dB
0.8 dB
AIR-CAB010LL-N
Interconnect
10-ft low loss   cable, one straight N connector, one 90-degree N connector
0.9 dB
1.5 dB
AIR-CAB020LL-R
Interconnect
20-ft low loss   cable, one RP-TNC plug, one RP-TNC jack
1.3 dB
2.5 dB
AIR-CAB050LL-R
Interconnect
50-ft low loss   cable, one RP-TNC plug, one RP-TNC jack
3.4 dB
5.75 dB
AIR-CAB100ULL-R
Interconnect
100-ft ultra low   loss cable, one RP-TNC plug, one RP-TNC jack
4.4 dB
7.25 dB
AIR-CAB150ULL-R
Interconnect
150-ft ultra   low loss cable, one RP-TNC plug, one RP-TNC jack
6.6 dB
11 dB
AIR-ACC2537-060
Bulkhead   Extender
5-ft (60 inches)   RG-58 type cable with one RP-TNC plug and one RP-TNC jack
2 dB
3 dB
