CCMUser Password Update error
Aug 26th, 2009
When using CCMUser, the user tries to change their password. When then try to save they get the following error:
missing key in referenced table for referential constraint (informix.tk_enduser_tklocale)
The kicker is the password is actually updated and everything works.
Has anyone seen this issue before?
Overall Rating: 5 (2 ratings)
mtashiro Wed, 08/26/2009 - 08:49
It's working now. Change the Locale from none, saved and now the error is gone.
kodre Tue, 07/13/2010 - 06:46
Thank you for finding the fix Mark! A user just brought this to my attention this morning. To clarify; under the end user configuration, change the User Locale field from "none" to what ever you may be using (in my case it's "English, United States").
