asa 5505 web acces
Aug 26th, 2009
I have a problem with my setup on asa 5505.
Version of cisco is 8.0.2
At the begin all the IP in the inside interface have a web access.
I add a static rule for one IP of the inside interface , and after for this IP the web access does not run.
My question is How can I resolve this problem ?
My configuration is :
interface Vlan1
nameif inside
security-level 100
ip address
Interface Vlan2
nameif outside
security-level 0
ip address
static(inside,outside) netmask
For the inside IP the web access does not run.
Thanks by advance for your response
Yudong Wu Wed, 08/26/2009 - 09:33
- Is IP a valid IP in your network?
- If you are talking about web access to the internet, is not a public IP, do you have another NAT device to nat it to a public IP?
- If you are positive on the above question, can you "clear xlate" and try again.
Eric Arnould Wed, 08/26/2009 - 22:39 is the IP Wan of the Cisco.
I have a route to a getway :
route outside 999.999.999.999 1
No is not a valid IP.
I am talking about web acces to the internet
I don't have another NAT device.
I had to say that I need to translate the IP in because I am using it in a VPN :
access-list no_nat extended permit ip host
crypto map vpn 11 set peer 888.888.888.888
The VPN is working.
I had to translate the IP because I will have 11 Cisco for 11 diferents sites and they all will have the same local IP ( and I need to setup a VPN between all this 11 Cisco and my Cisco in central.
Yudong Wu Thu, 08/27/2009 - 06:27
1. Based on your info, you have overlap IP between the sites. So you do need NAT ip to before the packet goes into VPN tunnel. ACL no_nat will not be used.
2. Will the traffic to the internet go to VPN tunnel first and then access internet from your central site? Or it will access the internet locally? I don't have the full config of this ASA and not sure if you are using split-tunnel.
3. My guess is:
- You have dynamic nat configured on this ASA to NAT the traffic to internet
- After you add static NAT for host, it will take priority over dynamic nat and as a result it will be NATed to a private IP. Therefore, no internet access anymore.
- If the above is true, you should use a Policy static NAT here.
static (inside,outside) access-list VPN
access-list vpn permit ip host
Eric Arnould Fri, 08/28/2009 - 01:19
Traffic to Internet must be locally.
A part of my configuration is :
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address 888.888.888.888
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
boot system disk0:/asa802-k8.bin
access-list EURODATA extended permit ip host
global (outside) 1 interface
nat (inside) 0 access-list no_nat
nat (inside) 1
static (inside,outside) access-list EURODATA
dynamic-access-policy-record DfltAccessPolicy
crypto ipsec transform-set set1 esp-aes-256 esp-sha-hmac
crypto ipsec transform-set set2 esp-3des esp-sha-hmac
crypto map vpn 11 match address EURODATA
crypto map vpn 11 set pfs group5
crypto map vpn 11 set peer 999.999.999.999
crypto map vpn 11 set transform-set set1
crypto map vpn interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 2
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
With this configuration :
Internet locally for is OK
VPN for is not OK , when a look the packet in cisco central I see the ip comming but not
Eric Arnould Fri, 08/28/2009 - 07:38
I followed your instructions and all is OK now.
We can say that the problem is resolved.
Many thanks for your help
Best regards
Eric Arnould , EURODATA France
