Softphone issue with CUCIMOC
Aug 26th, 2009
Has anyone had an issue with getting CUCIMOC softphone to register. I never had this issue when we were testing in Cisco training labs.
In our lab, we have everything up on vmware in order to do a proof of concept. Everything works "except" CUCIMOC softphone will not register. Sniffer shows request to read CUCIMOC config.xml file. But softphone never registers. No SIP invite in traces.
We have no login issues and control of cisco deskphone works fine. We have checked all paramaters mutiple times, and everything is configered according to instructions.
Ironically, we're also deploying Cisco Presence in proof of concept (business wants to see this as well). Same issue with CUPC, no login issues, deskphone control works great, but softphone doesn't register (times out). Capabilities for CUPC is checked in callmanager.
We are just using default DLU's that come with UCM. Is it possible since I don't have the CUCIMOC license file uploaded (nor the CUPC license) that this is the issue? I had thought that those both just add DLU's to box, so as long as you have DLU's you don't need to worry about CUCIMOC or CUPC license?
Any comments or suggestions would be great. UCM is 7.1, Presence is 7.0
thanks in advance,
Overall Rating: 3 (2 ratings)
htluo Thu, 08/27/2009 - 04:55
  • Red, 2250 points or more
I'd recommend you do a packet capture on the client side.
See if there's any SIP registration request from the client. If not, either the software (CUCIMOC/CUPC) is malfunctioning. Or they cannot resolve the destination name into an IP address.
Michael
http://htluo.blogspot.com
Tommer Catlin Thu, 08/27/2009 - 08:21
  • Green, 3000 points or more
Any DLUs in your system will work. YOu may not have the correct format for the Device named correctly
Should be CSF and then login name for LDAP.
so john doe is jdoe. his Device would CSFjdoe
UCcomp2007 Thu, 08/27/2009 - 10:47
No SIP registration shows up in sniffer.
Device names do conform.
We're going to try this on current production servers over the weekend.
thanks for the input.
Tommer Catlin Thu, 08/27/2009 - 10:49
If you just loaded the Device pack for CUICMOC, you have to reboot the server also. Was this done?
UCcomp2007 Thu, 08/27/2009 - 11:55
HI Tcatlinins.
This was done. we've restarted tftp services several times, restarted server several times. We have done this in the Cisco beta testing and was quit easy. Now we have it on new vmware environment and running into this issue.
We have double/triple checked all settings.
The only difference from when we did in as part of beta testing, is now it's in UCM running in vmware, before it was on actual UCM appliance.
jedellerby Wed, 12/30/2009 - 06:27
Did you get anywhere with this issue?
I have a similar issue with the softphone not registering, or even trying to (no SIP traffic). My softphone status screen is showing no Server Address and a status of 'disconnecting' so no doubt that is my root issue, but I don't know how to fix that problem.
Does the softphone config come from a TFTP download or is it driven by registry settings? I can't see in either case why it should be wrong.
Deskphone mode seems to work ok, although I can't drag and drop user numbers on to the phone icon. I'm not sure if that's a dial rule related issues, I've yet to troubleshoot that one.
Thanks for any pointers,
Jed
Tommer Catlin Wed, 12/30/2009 - 08:23
The group policy for the CUCIMOC will have the TFTP information for the softphone.  If you have not configured the GP in AD for this, then this is why it's not working.
Once you configure the GP with the correct settings, it will then update the client PC (15 minutes or so).  Restart the client PC or restart the client.
jedellerby Wed, 12/30/2009 - 12:35
I'm not using GP, this is a single client wich I applied the .BAT file to. I saw a download occur when I first logged in the user, this downloaded the CSF framework .. but I think this is an HTTOP download.
I have the TFTP server set in the registry settings, and I have .cnf.xml file in the Client Services Framework/config directory which I'm assuming was pulled via TFTP. However, there's no server IP address filled in the cnf.xml file and I would have thought that file would have defined the softphone server.
I haven't setup any CAPF details ... is that a requirement?
Jed
jedellerby Fri, 01/01/2010 - 09:15
I've fixed this particular issue now. I had two clients built and each had different issues which were solved by the following steps:
- CLIENT 1 - Added in CUCM host to hosts file to allow lookup to owrk correctly. One of the clients wasn't a member of the domain so didn't have any DNS setup on it (the .cnf.xml file download worked, but then the connection process referenced the CUCM hostname which couldn't be resolved. I could see this error in the client CSF log files)
- CLIENT 1 - Reassociated user and devices in CUCM from scratch, not sure if this had any impact or not
- CLIENT 2 - Reassociated user and devices in CUCM from scratch, not sure if this had any impact or not
- CLIENT 2 - Opened up local firewall. I realised the TFTP download wasn't working on this client and this was simply a firewall issue.
My next issue is getting the drag and drop feature working for contact dialing, at the moment I simply get the no entry sign when I try to drag and drop. Can anybody tell me what I should see .. I assume a 'plus' sign or something when it's working?
I've not set any dial rules up so I'm guessing this is where I need to focus my efforts. I also have an Outlook Integration error on my MOC status saying it cannot synch with the Outlook Address Book, so I guess this could be the source of this error too.
Anybody care to comment as to which  is the most likely to resolve this issue, Outlook Integration error or dial rules?
Jed
