Sample Config - IDSM-2
mikedawson2005
I'm looking for a sample config for a IPS IDSM-2. I've been reviewing the configuration manual and love the excruciating detail, but would like to work from a sample config. Maybe just the basics to get started and then I can add stuff in later.
Any samples would be most appreciated.
Mike
rhermes
Level 7
Level 7
I assume you're looking for the 6500/7600 config since the IDSM sensor configs are identical to the appliance sensors.
There's two ways you can run traffic throught a sensor, promiscious and in-line. Here's a simple promiscious config:
intrusion-detection module 9 management-port access-vlan 101 (puts the ISDM in slot 9 management port on VLAN 101)
intrusion-detection module 9 data-port 1 capture allowed-vlan 1001,1002,1003 (sends the contents of those VLANS to port 1 of the IDSM)
Thnaks for the info. I guess, with all the commands and detail in the configuration manual that there would be a lot more to it than this.
Mike
You need to decide the mode you want to run your IPS in? Promiscuous, Inline (VLAN/Interface pair) ?
Here are two examples from CCO:
https://www.cisco.com/en/US/products/sw/secursw/ps2113/products_configuration_example09186a0080876d9f.shtml
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_example09186a00809c37cb.shtml
Farrukh
Farrukh,
Excellent, perfect, just what I needed...Thanks!
Mike
