08-26-2009 11:16 AM - edited 03-15-2019 07:31 PM
I have a scenario where I have 20 extensions in no particular order. I presently map DIDs inbound to these 20 extensions using these translation rules which works fine.
voice translation-rule 1
rule 1 /^6880$/ /7250/
rule 2 /^6881$/ /7106/
rule 10 /^6883$/ /7245/
voice translation-rule 2
rule 1 /^6890$/ /7230/
rule 10 /^6891$/ /7225/
I now need to have the reverse take effect when making outbound calls. So if extension 7230 makes an oubound call it would show on the Caller ID as 6890.
I am only able to apply one translation profile to the outbound POTs peer but this only will accomodate half the translations.
How do I get all these translations to appear on a single outbound POTS?
Solved! Go to Solution.
08-26-2009 12:49 PM
dial-peer voice xx voip
answer-address yy
translation-profile kk incoming
codec g711a
no vad
Then make as many profiles and ruleseare needed.
Please remember to rate useful posts with the scrollbox below.
08-26-2009 12:10 PM
How the call comes in ? You can translate via individual voip DPs with answer-address.
08-26-2009 12:15 PM
Not sure I understand. Inbound calls are working using the dial-peers below. How do I accomplish the same thing but for outbound dialing?
dial-peer voice 702 pots
translation-profile incoming DID1
incoming called-number 688.
direct-inward-dial
dial-peer voice 703 pots
translation-profile incoming DID2
incoming called-number 689.
direct-inward-dial
08-26-2009 12:17 PM
Where the calls are going ?
You can have incoming voip DP and apply answer-address there.
08-26-2009 12:23 PM
Below is what have done so far. Could you provide an example of how this would be done using answer-address?
voice translation-rule 3
rule 1 /^7230$/ /5552226890/
voice translation-profile DID3
translate calling 3
dial-peer voice 100 pots
trunkgroup 1
translation-profile outgoing DID3
destination-pattern 9[2-9]......
direct-inward-dial
forward-digits 7
08-26-2009 12:32 PM
Can you answer my question? Do you have CM or CME ?
08-26-2009 12:34 PM
We have centralized CM and will be using SRST (fallback) at this site.
08-26-2009 12:49 PM
answer-address yy
codec g711a
no vad
08-26-2009 12:55 PM
I am just missing how this is going to work for outbound calls. In your example which command is triggering the outbound translation to the PSTN.
08-26-2009 01:02 PM
Please review the fundamentals of Cisco VoIP. for each call there is an incoming and an outgoing DP, you can use either or both for number manipulation.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
08-26-2009 01:26 PM
I'll review the doc and get back to you.
08-27-2009 08:08 AM
I reviewed the doc and I was able to get it working using the answer-address.
Thanks for your help.
