carenas123 Tue, 09/01/2009 - 07:17
  • Silver, 250 points or more
To copy the startup configuration file from the Flash memory SIMM to a Flash PC Card once the Flash PC Card is formatted and ready to use.
Copying the Startup Configuration File to the Flash PC Card.
8540CSR# copy startup-config slot0:
To create a backup copy of your system image, or to verify that the copy in Flash memory is the same as the original file on disk, you can copy system images from Flash memory to a Trivial File Transfer Protocol (TFTP) server.
