08-26-2009 02:23 PM
is there any document how to integrate WLSE with CM v5.2.
Solved! Go to Solution.
08-26-2009 03:10 PM
Search the Campus Manager context sensitive help for "WLSE". Essentially, as long as the WLSEs are in DCR, and managed by Campus Manager, UT integration will just work. the one caveat is you have to disable "Enable User Tracking on Access Points" under Campus Manager > Administration > User Tracking > Acquisition, and you must have configured HTTP credentials for the WLSEs in DCR.
08-26-2009 03:10 PM
08-27-2009 11:35 AM
Thanks!!
