Reserver IP address via DHCP
Answered Question
Aug 26th, 2009
I defined a pool of DHCP on IOS software, I want to reserve a IP address to host, I made it, only that doesn't assigned the IP address that I defined in the pool
Help? How I can to do it?
Example
ip dhcp pool guestimport all
network 172.23.12.0 255.255.255.0
default-router 172.23.12.254
address 172.23.12.231 hardware-address 0100.14c2.c6ec.42
Correct Answer by Juan Carlos Ari... about 7 years 10 months ago
Jorge,
First you have to create an IP dhcp pool for your clients, then for a fixed IP address create another IP dhcp pool.
Example, if your MAC is 12.34.12.34.12.34
ip dhcp pool Client1
host 172.23.12.200 255.255.255.0
client-identifier 0112.3412.3412.34
Release the IP and renew IP address and IP address 172.23.12.200 will be assign it.
Hope this helps.
JC Arias
Correct Answer by paolo bevilacqua about 7 years 10 months ago
Do not use hardware-address.
Use client-identifier, chek "show dhcp server lease", you have to add one extra byte to the mac.
Overall Rating: 4.5 (2 ratings)
Correct Answer
paolo bevilacqua Wed, 08/26/2009 - 16:08
  • Hall of Fame,
    Founding Member
Correct Answer
Juan Carlos Ari... Thu, 08/27/2009 - 10:24
Jorge,
Hope this helps.
JC Arias
