Router and L3 switch: vlan communication
Aug 26th, 2009
Im confuse. Lets say I have a L3 switch with vlan configured. Do I still need a router if I want different vlans to communicate. Though I have already network layer device, L3 switch.
Can anyone elaborate this. thanks
yagnesh_tel Wed, 08/26/2009 - 18:20
You don't require router for vlan communication if you have layer 3 switch. Layer-3 switch will take care of routing between VLANs provided that you create SVI interfaces for each of those VLANs on switch.
yongsikahn Wed, 08/26/2009 - 18:24
no,, I think you don't need to use Router.
because the L3 can be supported routing.
so, if you want to put ip in the interface or you want to make a new vlan for access other vlan, you need to configure at the below.
first, Go to interface or VLAN interface
second, enter no switchport
third, give the IP address
fourth, i think you need Static routing or some other routing protocol method go other Vlan.
Jon Marshall Wed, 08/26/2009 - 21:47
You do not need a router to route between your vlans in this case. What you do is create L3 SVIs (Switched Virtual Interfaces) for each vlan.
So assuming you have 3 vlans on the switch -
vlan 10
vlan 11
vlan 12
switch(config)# int vlan 10
switch(config-if)# ip address
switch(config)# int vlan 11
switch(config)# int vlan 12
once you have created the interfaces as above then your vlans should be able to communicate.
Note that you do not need any static routes or dynamic routing on the switch because all the L3 interfaces are seen as directly connected. If you wanted to connect to another L3 device then you would need static/dynamic routing to exchange routes.
Note also you may have to enable routing on the L3 switch ie.
switch(config)# ip routing
