ACE URI rewrite
Aug 26th, 2009
I need to rewrite URI. So for instance user requests:
I need to rewrite it to
I am looking at action-list and trying to figure out which header name to use for the URI rewrite. (This is not an SSL scenario, http in/http out)
header rewrite {request | response | both} header-name header-value expression replace patte
Gilles Dufour Wed, 08/26/2009 - 22:08
this can't be done with an action-list.
The ACE does not modify URI.
However, you can create a rule to intercept the uri "/" and send an http redirect to "/blah".
This has the same effect.
