Gateway total call restriction
Adrian Saavedra Thu, 08/27/2009 - 20:38
Hi Naresh,
CME can do a limited amount of CAC itself without a gatekeeper, either by limiting the number of simultaneous calls associated with each dial peer or by using RSVP.
But, per dial peer call counting doesn't work well if you're using more than one dial peer per WAN link, and RSVP requires end to end support within your network.
Hope it helps, if it does please rate.
Best regards,
- Adrián.
Nicholas Matthews Fri, 08/28/2009 - 06:37
There are a number of call treatment options.
You can do it on CPU utilization, a certain amount of calls over an interface, and many others.
There's more information on the call treatment and call threshold information here:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t11/feature/guide/ftcac58.html#wp1069155
As well, the 'call treatment' and 'call threshold' command reference is helpful.
hth,
nick
