No input and output
Aug 26th, 2009
Hi ALL:
I see the last input and 30 sencond input and output as 0.
What my understandinig is since CEF is enabled the packet are not hitting the CPU and thats why i dont see any input and output.
Is that right or i am missing something.
This is 4507r with Sup V-10GE .
GigabitEthernet7/16 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 001f.9e46.a67f (bia 001f.9e46.a67f)
Internet address is x.x.x.x
MTU 1500 bytes, BW 4096 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
L3 in Switched: ucast: 488526834 pkt, 57240662759 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 530401074 pkt, 374322172171 bytes - mcast: 0 pkt, 0 bytes
488561771 packets input, 67080948138 bytes, 0 no buffer
Received 34128 broadcasts (0 IP multicasts)
530439677 packets output, 384140361152 bytes, 0 underruns
101 output errors, 15 collisions, 0 interface resets
0 babbles, 101 late collision, 0 deferred
0 lost carrier, 0 no carrier
Chao
Vishwa
gthermaenius Thu, 08/27/2009 - 11:38
If you have traffic on the interface you should see input and output rate regardless of cef. Do a clear counters, put on a extended ping on the connected equipment on that interface and you should see the rate.
vishwancc Thu, 08/27/2009 - 19:48
Hi Gunnar,
Thanks for the reply.
I have done that and there is traffic but i only see increase in L3 packets no increase in Input and output , any idea why is this happenning.
Chao
Vishwa
