Router IP Traffic-Export error message.
Aug 27th, 2009
I'm trying out the RITE feature on 12.4T. I've set it up on a dialer interface used for PPPoE with ip address being received from the AC.
When I apply the profile to a dialer interface and start capturing, I get the error ".. input pak export : No hwsb found".
However when applying it to a regular ethernet interface it works fine.
What does the error mean, and on which interface types is RITE supported?
Best regards,
Johnny Karms Pedersen
tstanik Wed, 09/02/2009 - 07:34
You are hitting bug CSCsh93535 RITE doesn't export packets when they are getting process-switched. RITE does not capture all packets when ios firewall (IP INSPECT) is configured on the same device. To workaround his issue does not effect 12.4(9) T and higher. Disable ip inspect, or Upgrade to 12.4(9) T or higher.
