css redundancy
Aug 27th, 2009
hi,
looking to have a failover solution for css. below is the version
Version: sg0750004 (07.50.0.04)
Flash (Locked): 07.10.1.02
Flash (Operational): 07.50.0.04
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
questions
do we need to upgrade the version
how does the redundacny works
all are servers are directly connected to a single css. when we connect the second css how can we connect these servers? we can team them but connecting directly to css can cause problem. ideally we want to connect them directly to the servers and thats how the original config is on the existing servers
pknoops Thu, 08/27/2009 - 05:38
  • Bronze, 100 points or more
Ideally for redundancy you would need to connect the servers to an another switch and then the 2 redundant css boxes into the same switch.
The code you are running is old and you would want to run the latest 8.20 code on CCO.
http://www.cisco.com/kobayashi/sw-center/index.shtml
go to the section Application Networking Services for the CSS code (WebNS)
