08-27-2009 05:12 AM - last edited on 03-25-2019 10:41 PM by ciscomoderator
I have tried 4 or 5 times now to reset my UC520 back to factory settings. I have both the 7.0.3 and 7.1.1 files and CCA 2.0.1.
I have already erased the flash and nvram and only loaded the factory cfg file and the uc500-advipservicesk9-mz.124-22.YB IOS files back onto the flash and copied the cfg file to startup and powered off and back on....
So far so good....
I now select the 7.1.1 file from the CCA manitenence window it starts doing is stuff then half way through it errors out saying ftp or tftp is running which it is not....
I look at the logs and this is what I see:
++: DEBUG: : WARNING:: This command will install the necessary software to
WARNING:: complete a clean install. It is recommended that a backup be done
WARNING:: before installing software.
Would you like to continue? [n]
++: DEBUG: : Software install using RAM
Downloading ftp cue-main.ise.7.0.3.pkg
++: DEBUG: : Error: Download error
Can not download cue-main.ise.7.0.3.pkg
error code 0 : error type 'couldn't connect to host'
UC500-CUE#
++: DEBUG: : [CliCmd:'config t
',null, CliCmd:'line vty 0 4
',null, CliCmd:'exec-timeout 10 0
',null, CliCmd:'end
',null]
',null, CliCmd:'line vty 5 100
',null, CliCmd:'end
',null]
++: DEBUG: : Duration for [upd Device<--Mirror() @ com.cisco.cpnm.features.defn.swupgrade.SwUpgradeTask$SwUpgradeTreeTable] = [675108] msec.
++: DEBUG: : Duration for [upd Device<--Mirror() @ com.cisco.cpnm.frmwrk.gen.wd.WDTreeTable] = [675123] msec.
++: DEBUG: : Progress Bar Task close() called
++: DEBUG: : WDTask::setHierarchy .ProgressBarDialogTask
++: DEBUG: : Progress Bar Task showProgressBar()- after launchModalOptionDialog()- Task.getWizarDialog() = null
++: DEBUG: : Progress Bar Task terminated
Can anyone help?
Brian
08-27-2009 05:55 AM
netstat -a on your PC just to make sure someone doesnt have binding to FTP (which CUE uses).
After that, I would look at the status of CUE from SSH/Telnet window into your UC520:
(AND THIS IS ONLY if not a production system or you dont want to save anything and really ant to rest it all)
UC520# service-module integrated-Service-Engine 0/0 status
And if its not happy:
UC520# service-module integrated-Service-Engine 0/0 session
UC500-CUE> offline
!!!WARNING!!!: If you are going offline to do a backup, it is recommended that you save the current running configuration using the 'write' command, prior to going to the offline state.
Putting the system offline will terminate all end user sessions.
Are you sure you want to go offline[n]? : y
UC500-CUE(offline)> restore factory default
!!!WARNING!!!: This operation will cause all configuration and data
on the system to be erased. This operation is not reversible.
Do you wish to continue[n]? : y
Restoring the system. Please wait .....done
System will be restored to factory default when it reloads.
Press any key to reload:
Then try again from CCA.
08-27-2009 06:25 AM
Hi Steve,
Yeah dont worry not a production system, my own private system....
Ok so factory reset the CUE no ftp or tftp progs running or binded...
But it still drops out....
Is there a specific folder I should place the zip files in I see the 7.1.1 zip file actually loads the 7.0.3 files......Is this causing the issue as it seems to drop out...
Should I have internet connectivty when resetting the device as I am switching directly between my other router and the UC520 which is not connected yet to the inet....
I have reset the flash cards nvram startup config 7 times now and I still get the same result.... Next time I will take a screen shot if that is ok?
Is there anything else I should look at
08-27-2009 06:34 AM
Hi Brian,
Using CCA, I usually select ALL in the SW Upgrade screen and point to the local UC520_7.x.x.zip file on my PC.
No need to unzip anything. It does that for you.
No need for internet connection at this point or anytime during upgrade. You PC is on the LAN switch port of the UC and your wireless NIC is disabled (dual NIC causes havoc).
The bundle zip SW has everything you need and is on your PC.
Do you select 'auto format flash" button on the SW Upgrade GUI window of CCA?. I suggest you do, but thats not that part thats failing, just that the new directory structure is supported more ;-)
Can you try to download the file again, or download 7.0.3 and see if that works better (the official bundle)?
What did the 'Status" say when your check CUE. Was it online and running?
How many systems do you have and is this the only one with trouble?
Sorry for all the questions. If we cant get this figured out (should be something basic) we may need you to collect the tech support zip from CCA and share it here so CCA team can examine....
Try turing off or stopping any service running on your PC that you dont need before reattempting. Perhaps reboot it first and then stop any services that are not required.
Let us know.
08-27-2009 08:07 AM
Still the same issue:
Following steps were taken:
1) Disabled wireless nic as using hardwired
2) Unistalled Java latest version as it seem to make my PC hang
3) Re-installed CCA 2.0.1
4) Reset all aspects of the UC520
tried to get the log file only to be told it doesnt exsist and would I like to create one.....
This is driving me mad.... I had no issues before I have done this action before.......the on ly things that have changed is the version of the CCA/ Java and my antivirus from Symantec to Mccafee.....
Any other ides since I cant even get the log file now.... I am think it must be related to Java.... Can you tell me which version I should have that works well with CCA2.0.1
I even tried the 7.0.3 image and it crashed at the same point as the 7.1.1
Brian
08-27-2009 10:28 AM
08-27-2009 11:07 AM
Way to go!! Thanks.
I am sending to the CCA team now.....
hopefully wont take too long, as they are a very responsive team.
08-27-2009 11:10 AM
Thanks Steve,
Think I should try going back to version 1.9.1 ? Or should we wait to see what the CCA team say?
Brian
08-27-2009 11:13 AM
I would rather not put you through any more trouble. Lets give them some time.
08-27-2009 11:15 AM
Ok Thanks Steve....
08-27-2009 12:13 PM
OK, Development took a look and have two questions:
08-27-2009 12:18 PM
Hi Steve,
Yup trying to install 7.0.3
IP Dets:
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit Controlle
r
Physical Address. . . . . . . . . : 00-18-8B-A1-EE-4E
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::90dd:558c:57f3:fada%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.10.11(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 27 August 2009 19:06:00
Lease Expires . . . . . . . . . . : 28 August 2009 21:14:59
Default Gateway . . . . . . . . . : 192.168.10.1
DHCP Server . . . . . . . . . . . : 192.168.10.1
DHCPv6 IAID . . . . . . . . . . . : 201332875
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0F-93-40-14-00-18-8B-A1-EE-4E
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
And yup I am using Vista Ultimate SP2
Hope this helps
08-27-2009 12:53 PM
08-27-2009 12:58 PM
Steve,
I hope this is what you are looking for:
UC520>
UC520>en
Password:
UC520#serv
UC520#service-module int
UC520#service-module integrated-Service-Engine 0/0 sess
UC520#service-module integrated-Service-Engine 0/0 session
Trying 10.1.10.2, 2002 ... Open
se-10-1-10-1#
se-10-1-10-1#
se-10-1-10-1# ping 192.168.10.11
PING 192.168.10.11 (192.168.10.11) 56(84) bytes of data.
--- 192.168.10.11 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4003ms
, ipg/ewma 1000.993/0.000 ms
se-10-1-10-1#
08-27-2009 01:17 PM
OK , thats not good :-)
On your UC520, do you have the interface built for CUE?
A good way to check is to do a
#sh ip int brief
#sh interface In0/0
If you think these interfaces are not correct (if they got changed by accident...
I think you perhaps want to factory reset your IOS/CME manually (easiest way to get it back the way it should be)
# copy
# reload
