Strange Night-service behaviour
clark-computers
My night-service on my Cisco 2821 (running CME 7.1 IOS 12.4(22)YB1) is acting up! It's a bit weird, here's my setup and the problem I'm having.
The config is set so that at 5pm the system goes into active night-service and at 9am night-service is disabled. There are two ephone-DNs that have CFNS config. When night-service is disabled, their respective CFA settings should have them go to the AA for one and a parallel voice hunt-group form the other. When night-service is active, they should both go to their voice mailboxes on the CUE. These ephone-dn's are not used as a button on any IP phone. Here's the config:
ephone-dn 191
ring external primary
number 01234511441
label Main Line
description Main Line
name Main Line
call-forward all 6001
call-forward night-service 6000
hold-alert 15 originator
night-service bell
ephone-dn 192
number 01234511900
label Support Desk
description Support Desk
name Support Desk
call-forward all 1900
night-service bell
The problem I have is that, in actual operation, when night service is disabled, ephone-dn 191 does the CFA to 6001, but ephone-dn 192 does the CFNS to 6000. When night-service is enabled, ephone-dn 191 does the CFNS to 6000, but ephone-dn does the CFA to 1900.
When I remove the CFNS config line on ephone-dn 192, it does the CFA to 1900 correctly. IF I enter the CFNS config again, it still doies the CFA to 1900. When I manually activate night-service, it still does the CFA to 1900 and then the CFNS 6000 when night-service is disabled.
Really hope that you can lend a hand with this one. If you need my full config, let me know and I'll email it through.
Stu
Rob Huffman
Hi Stu,
Not sure if I understand completely (no surprise :). Maybe it is this bug that effects your IOS version;
CSCsx33278 Bug Details
CFA being reenabled accidentally after turning on and off night service
Symptom: call forward all is being re-enabled on a dn after being removed.
Conditions: night service is activated and then deactivated on the dn.
Workaround: none.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 7 Days
Product
Cisco IOS software
Technology
1st Found-In
12.4T
12.4(20)T2
Known Affected Versions
Fixed-In
12.4(24.3)T
12.4(24.5.2)PIC1
12.4(24)T1
12.4(22)T2
12.4(22)YB2
12.4(24)YG
12.4(24)GC1
12.4(22)XR
Hope this helps!
Rob
Rob Huffman
Hi Stu,
Workaround: none.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last 7 Days
Product
Cisco IOS software
Technology
1st Found-In
12.4T
12.4(20)T2
Fixed-In
12.4(24.3)T
12.4(24.5.2)PIC1
12.4(24)T1
12.4(22)T2
12.4(22)YB2
12.4(24)YG
12.4(24)GC1
12.4(22)XR
Hope this helps!
Rob
Thanks, man: I'll try and upgrade and let you know...
Perfect: upgrade to 12.4(24)T1 resolve the problem.
Thanks, Rob!
Stu
Great work Stu! You are most welcome. Bugs can really mess things up thats for sure.
Have an excellent weekend!
Rob
