Estimating phone firmware upgrade duration
Answered Question
Aug 27th, 2009
I need to upgrade a large number of cisco phones spread across multiple sites with varying bandwidth.
Is there any way I can estimate the time it will take to upgrade a specific site based on the number of phones, firmware image size, WAN bandwidth etc?
Correct Answer by Jaime Valencia about 7 years 11 months ago
Table 3-4 TFTP File Transfer Times for SCCP Devices
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/netstruc.html#wp1050963
If not your version just open the SRND from your version in same chapter for specifics.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
nstathak Thu, 08/27/2009 - 21:09
why don't you enable peer firmware sharing first then perform your upgrades, it will save lots of time when upgrading firmware.
There are dependencies but if your lucky you'll using a similar phone type and thus pulling the image once over the WAN.
