CME Shared Line
Aug 27th, 2009
I would like to set up a shared line for 13 ephones in CME 7.1 on their second button. There is fractional PRI at the site so we would like only to have 6 calls be active at once with the 7th going busy.
Any thoughts?
Thanks.
Overall Rating: 2.8 (4 ratings)
tnguyen620_2 Thu, 08/27/2009 - 11:10
Would the setup resemble this?
ephone-dn 1 octo-line
number XXXX
ephone 1
mac-address xxxx.xxxx.xxxx
button 2:1
ephone 2
mac-address xxx.xxxx.xxxx
button 2:1
Where would I put the busy-trigger-per-button or max-calls-per-button command? Would they go on each ephone? Is there something to place on the ephone-dn?
Paolo Bevilacqua Thu, 08/27/2009 - 11:13
Yes, just just do these setting as you deem appropriate. Everything is explained in the manual, and there isn't anything special about.
Please remeber to rate useful posts with the scrollbox below.
