NAT to conceal outside global IP
Hey Pros,
I have 2 networks with a router between them.
Network A --router-- Network B
Network A= inside
Network B= outside
I want it so that when Network B sends traffic destined through the router, Network A does not see the true IP of the host who actually sent the traffic, but sees an IP address from the router. Is this possible? I can do this easily with Linux using ip masquerade (ipmasq). Thanks pros!
Overall Rating: 5 (1 ratings)
John Blakley Thu, 08/27/2009 - 09:38
  • Purple, 4500 points or more
Here's an example:
Network B
int fa0/0
desc WAN
ip nat outside
int fa0/1
desc LAN
ip address 10.50.50.1 255.255.255.0
ip nat inside
ip nat inside source list 1 interface fa0/0 overload
access-list 1 permit 10.50.50.0
Anyone coming from 10.50.50.0/24 lan side will look like they're coming from 192.168.1.1.
HTH,
John
I'm trying to take this one step further. From you example, how would I make a static NAT entry where people connecting from f0/1 could be statically NATted to a host on f0/0?
For example, I want users to connect to a new IP address, 10.50.50.2 TCP port 80. Traffic gets NATted and sent to 192.168.1.2 port 8080.
I've tried:
ip nat inside source static tcp 192.168.1.2 8080 10.50.50.2 80
But this doesn't seem to work. Thanks!
