backup.pl vs. common services scheduled backup
Aug 27th, 2009
I need to perform an LMS 3.1 migration, and the first step is to perform a backup using the following command:
NMSROOT\bin\perl NMSROOT\bin\backup.pl backupdirectory
Since I already perform backups using the ciscoworks backup scheduler in Common Services, I was wondering if the backp used by the common services scheduler is the same as the backup.pl manual backup.
Thanks!
--Max
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/27/2009 - 09:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, it is. If you're absolutely sure you have a good backup, you can run the LMS 3.1 installer as:
setup.exe nobackup
That will skip the backup step. Then, you can restore your known good backup once LMS 3.1 is installed.
max12341234 Thu, 08/27/2009 - 10:26
Thanks for your help!
I plan to use the backup I already have to do a remote migration on a test machine.
