Automatically remove expired guest accounts
rkler
I have WCS 6.0 and under Administration -Settings - Guest User Settings, there is an option to automatically remove expired accounts. I checked that box and clicked saved.
I had some expired accounts but those were not removed. Do i need to restart the WCS service for that to work or does it only take effect with new accounts created after saving that setting?
any ideas?
Lucien Avramov
Level 10
Level 10
Try this with accounts created AFTER saving this setting, that should make a difference.
If not let me know.
I created some test accounts and they expired after. The "pre-existing" expired accounts had to be removed manually.
