BGP to OSPF redistribution with VRFs
Aug 27th, 2009
I am having a problem with redistribution of routes between BGP and OSPF when using VRFs mapping to VLANs between the PE and CE.
In this lab I've put together I have R4 and R5 communicating with eachother via BGP with MPLS. If I redistribute the BGP into OSPF and delivering the connection to the CE without VLANs it works fine. If I want to essentially keep the same primary network going into the other side of the BGP but send the VRF over a VLAN to the next router the redistribution doesn't happen.
In this example I have (R6) --ospf-- (R4) --BGP-- (R5) --ospf-- (R7)
Between R4 and R5 is the core network running ospf (R1 - R3).
Can anyone point me in the right direction why this isn't working? I am obviously missing something here.
Overall Rating: 5 (2 ratings)
jon.harald.bovr... Thu, 08/27/2009 - 12:29
R6 - running Multi-VRF (VRF-Lite)
router ospf 30 vrf POS
network area 0
try adding 'capability vrf-lite' to the ospf process on R6
and maybe also ad RD to the VRF?
Laurent Aubert Thu, 08/27/2009 - 12:30
Hi Mike,
You need to add capability vrf-lite under ospf process of R6 and R7 because they are configured with VRF-lite. This command will disable the check usually done on the PE to avoid routing loops.
