08-27-2009 11:38 AM
is that possible the compliance check to ignore case sensitivity while checking configuration?
Solved! Go to Solution.
08-27-2009 12:16 PM
Yes, if you use the regular expression ?i syntax. For example:
+ snmp-server community [#(?i)public#] RO
Will match public, PUBLIC, pubLIC, etc.
08-27-2009 12:16 PM
08-27-2009 12:21 PM
thanks a lot!
