3750 switch stack, wierd output of show spanning-tree
Answered Question
Aug 27th, 2009
Hello there,
So I have five 3750 switches in a stack. Show version, show switch, show switch stack-ports all show that they work properly. However when I do show spanning-tree then it has a port named "St5". On some vlans it's FWR and others BLK... Does anybody know what it's? Thanks!!
Interface Role Sts Cost Prio.Nbr Type
Po1 Desg FWD 3 128.488 P2p
Po2 Desg FWD 3 128.496 P2p
Po3 Desg FWD 3 128.504 P2p
St5 Back BLK 100 128.876 P2p
Correct Answer by Francois Tallet about 7 years 4 months ago
This is the stack port, which is used to sync STP information between members of the stack. The state is irrelevant here (don't worry about the BLK state). It should be hidden from the user. You can only see it because you have "debug spanning-tree event" enabled.
Francois
Overall Rating: 5 (1 ratings)
Correct Answer
Francois Tallet Thu, 08/27/2009 - 12:58
Francois
