RRM Channel Assignments
Aug 27th, 2009
I currently have RRM set to "On Demand" for channel assignments. I'm curious if anyone knows how a newly installed AP selects it's channel assignment after joining the WLC with RRM set to "On Demand" (without manually invoking a channel update). Does the AP randomly select a channel or use a factory default? Or does it actually select the best channel based other RF in the area since it's a new AP joining the WLC?
Any help is greatly appreciated.
ericgarnel Fri, 08/28/2009 - 06:01
  • Gold, 750 points or more
Assuming you are using DCA channels, the APs will communicate with each other & the controller to determine channel assignment (automatic enabled)
What version of code are you running?
I am on 6.0.182.0 and under DCA, I see the following options for DCA:
automatic
freeze
off
I see an "on demand" option under TX power level control
Trending Topics - Security & Network
