Display OSPF uptime
Aug 27th, 2009
Is there a nicer way to display the OSPF uptime of neighbors like "show ip bgp sum" does? Currently the only way is to use "show ip ospf ne det". But the output of that is too detailed to look over quickly.
We have a large network and when many OSPF adjacency's bounce at the same time, it's hard to tell if they've come back up, how long they've been up, or how long it has been down without having to compare it against the log file.
Paolo Bevilacqua Thu, 08/27/2009 - 14:44
If the information you're interested is there, but just too detailed, use some parsing/scripting tool to make it more readable.
Giuseppe Larosa Thu, 08/27/2009 - 22:52
Hello Patrick,
if your IOS supports it
sh ip ospf interface summary
is very handy and can tell you how many neighbors per interface are alive.
Otherwise you can easily filter
sh ip ospf neigh detail using | include or | begin.
for example
sh ip ospf nei det | inc ptime
should give you just the uptimes
Hope to help
Giuseppe
aldoleiva Sun, 12/08/2013 - 19:54
try... ( sh ip ospf nei det | i  Neighbor)
SPMB-SW1#sh ip ospf nei det | i  Neighbor
Neighbor 117.xxx.xxx.xxx, interface address 10.22.xxx.xxx
    Neighbor priority is 1, State is FULL, 6 state changes
    Neighbor is up for 3w1d
Running on Cisco 3750-X
c3750-ipservicesk9-mz.122-55.SE5.bin
usharanig Fri, 10/14/2016 - 22:58
Try this,
sh ip protocols.
It will show uptime for all ospf neighbors together under ospf protocol under "Last update".
It will be easier to view than sh ip ospf neigh
