Source-Based Black Holing in a VRF
Aug 27th, 2009
I am trying to setup Remote Triggered SBBH in a VRF, but it does not seem to be working.
I have the trigger router in a VRF connected to a PE (EBGP), but no matter what I configure on the PE, the next-hop is "inaccessible" for routes advertised by trigger. When I remove the VRF it is fine.
With 172.31.254.254 as my discard route, I have tried on the PE:
ip route 172.31.254.254 255.255.255.255 null 0
route-map FROM-TRIGGER
set ip next-hop 172.31.254.254
And I have tried:
ip route vrf INTERNET 172.31.254.254 255.255.255.255 null 0
set ip vrf INTERNET next-hop 172.31.254.254
As well as combinations of the 2 above.
Is this configuration supported in a VRF?
thank you,
Bryan
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Thu, 08/27/2009 - 22:43
  • Hall of Fame,
    Founding Member
Hello Bryan,
in MPLS VPN the BGP next-hop used in VPNv4 advertisements has to belong to the global table.
So first formulation should be correct.
You need to advertise in your IGP (OSPF or others) the next-hop ip address using a redistribute static.
if the next-hop is known in GRT you should see the vpnv4 prefixes with modified next-hop accepted on the other PE nodes.
Hope to help
Giuseppe
dodgerfan78 Fri, 08/28/2009 - 06:13
Hi Giuseppe, thank you for the reply. For brevity I will show you what I have for the Trigger and the PE router. I have the next-hop set to 172.31.254.254 and the null route is in the Global table.
TRIGGER = 192.168.2.2 (s1/0)
PE1 = 192.168.2.1 (s1/1)
TRIGGER
interface Serial1/0
description to PE1
ip address 192.168.2.2 255.255.255.0
router bgp 65086
no synchronization
bgp log-neighbor-changes
redistribute static
neighbor 192.168.2.1 remote-as 65000
neighbor 192.168.2.1 description PE1
neighbor 192.168.4.1 remote-as 65000
neighbor 192.168.4.1 description PE2
no auto-summary
ip route 12.12.12.12 255.255.255.255 Null0
PE1
ip vrf INTERNET
rd 100:1
route-target export 100:1
route-target import 100:1
interface Loopback0
ip address 10.1.1.1 255.255.255.255
interface Serial1/1
description TRIGGER
ip vrf forwarding INTERNET
ip address 192.168.2.1 255.255.255.0
router bgp 65100
no bgp default ipv4-unicast
bgp confederation identifier 65000
bgp confederation peers 65200
neighbor 10.1.3.3 description RR
neighbor 10.1.3.3 remote-as 65100
neighbor 10.1.3.3 update-source Loopback0
address-family vpnv4
neighbor 10.1.3.3 activate
neighbor 10.1.3.3 send-community extended
exit-address-family
address-family ipv4 vrf INTERNET
neighbor 192.168.2.2 remote-as 65086
neighbor 192.168.2.2 activate
neighbor 192.168.2.2 route-map SBBH in
no synchronization
exit-address-family
ip route 172.31.254.254 255.255.255.255 Null0
ip bgp-community new-format
route-map SBBH permit 10
set local-preference 250
With this config, PE1 accepts the route to 12.12.12.12 from Trigger and sets the next-hop to 172.31.254.254, however, this is what I get:
PE1#sho ip bgp vpnv4 all 12.12.12.12
BGP routing table entry for 100:1:12.12.12.12/32, version 24
Paths: (1 available, no best path)
Flag: 0x820
Not advertised to any peer
65086
172.31.254.254 (inaccessible) from 192.168.2.2 (192.168.4.2)
Origin incomplete, metric 0, localpref 250, valid, external
Extended Community: RT:100:1
PE1#
Giuseppe Larosa Fri, 08/28/2009 - 06:34
  • Hall of Fame,
    Founding Member
Hello Bryan,
I think that PE1 should receive a route with next-hop 12.12.12.12 and trigger should advertise a network with next-hop 12.12.12.12
12.12.12.12/32 should be advertised in IGP.
PE1 has a route to null0 for 172.31.254.254 and so when BGP checks if BGP next-hop is reachable it detects the problem.
have a look at
http://www.arbornetworks.com/index.php?option=com_docman&task=doc_download&gid=112
Hope to help
Giuseppe
dodgerfan78 Fri, 08/28/2009 - 06:41
But for source-based black holing to work you need to have the next-hop recursively point to NULL so the RPF check fails.
12.12.12.12 is the route I am trying to black hole. When PE1 receives traffic from 12.12.12.12 and performs an RPF check (on the other interfaces, namely the one connected to the ISP), PE1 should recursively see the next-hop as 172.31.254.254. This route points to NULL which is an invalid interface for RPF check and PE1 then drops the traffic.
This works without the VRFs. That's why I am wondering if it is supported in VRFs.
Giuseppe Larosa Fri, 08/28/2009 - 06:47
  • Hall of Fame,
    Founding Member
Hello Bryan,
sorry for my misunderstanding I was thinking of RTBH.
We can guess that MP BGP makes additional checks because the next hop is in GRT.
you are probably right and this feature is not working well with VPN traffic or some additional tricks are needed.
Hope to help
Giuseppe
dodgerfan78 Fri, 08/28/2009 - 06:52
That's why I thought the "set ip vrf next-hop" would work, but it didn't :/
I have got it to work by peering trigger with the routers downstream of the PE (multihop EBGP)...the Internet border routers ("CE"), so this may be the way I have to go.
Thanks for your time!
dodgerfan78 Fri, 08/28/2009 - 14:25
Think I figured it out. Instead of setting next-hop inbound from trigger. I set it outbound from the PE towards the RR. Then I have the global null route on all PE's and the RR and the triggered route is now accepted.
Giuseppe Larosa Sat, 08/29/2009 - 03:27
  • Hall of Fame,
    Founding Member
Hello Bryan,
nice to hear you have found the right tricks.
so the PE is setting the special next-hop towards RRserver that propagates this to all other PE nodes.
each node has a local static route to null0 for the special next-hop.
It might be interesting if you could post the working configuration that could help other people interested in the same feature.
I took part in some testing on Cisco Guard in that case all nodes send the traffic to a special PE node that diverts traffic to the Cisco guard that acts like a washer trying to "clean" the traffic.
So the special next-hop was advertised in OSPF and traffic was diverted to Cisco guard.
in this case you are discarding traffic locally on each node if I have understood correctly.
Best Regards
Giuseppe
Marwan ALshawi Sun, 08/30/2009 - 05:26
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
in the show ip bgp
the route shown not accessable by other bgp peers becuase your static route is global and the route-map applied under a VRF
u had to make your null route like:
ip route vrf INTERNET x.x.x.x y.y.y.y null0
