UC500 remote branch office
Aug 27th, 2009
I have one UC 500 with 48 users in site A and in site B I have a cisco 877W and spa9000 for IP telephony; (only 12 users)
I want to communicate both sites with IP telephony and I was thinking with vpn tunnel is the best option for de Site A call to Site B reading.
(Maybe if I haven't fixed IP address in site A and B, I Cam use some DyNDNS service?)
for example:
Site A:
dial-peer voice (extention_in_siteA)
destination-pattern (extention_in_siteB)
session target ipv4:(IP_in_SiteB)
Site B:
dial-peer voice (extention_in_siteB)
destination-pattern (extention_in_siteA)
session target ipv4:(IP_in_SiteA)
somebody Can give any clue.......
I hope that you can help me
thanks a lot of
exonetinf1nity Fri, 08/28/2009 - 04:38
I would highly recommend that you create a VPN tunnel between the two sites and apply QOS for voice on a per tunnel.
Then yes you could add H.323/SIP dial peers to each system and make calls between the two.
Example:
First Site, Extension Range 100-199
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
no update-callerid
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 1 voip
preference 1
destination-pattern 2..
voice-class h323 1
session target ipv4:192.168.20.1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
Second Site, Extension Range 200-299
voice service voip
sip
no update-callerid
voice class h323 1
preference 1
destination-pattern 1..
voice-class h323 1
session target ipv4:192.168.10.1
