08-28-2009 12:57 AM - last edited on 03-25-2019 07:52 PM by ciscomoderator
Greetings, i have a UC520 connected to an ISDN2e connection and dont appear to be getting caller id presented for inbound calls.
I have enabled the following debug and cant see the calling number being presented by the carrier.
"debug voice dialpeer inout"
Snippet:
002670: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=509, Voice-Interface=0x865BD57C,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
002671: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=10
002672: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=509, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
002673: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
002674: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=509, Peer Info Type=DIALPEER_INFO_SPEECH
002675: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=509
002676: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
002677: Aug 28 08:58:38.988: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20027
002678: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002679: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002680: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersCore:
002681: Aug 28 08:58:38.992: //-1/CFD8C44B8039/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Can i ask if this is normal behavior for ISDN2e circuits?
Solved! Go to Solution.
08-28-2009 02:05 AM
It can be confirmed, no calling number is present, and you should complain to telco.
If their asnwer is "all Ok", show them the trace above.
08-28-2009 01:57 AM
Please take "debug isdn q931". Do not enable any othet debug.
08-28-2009 02:03 AM
This is a call from my mobile to extension 509. The call was disconnected before being answered.
I do have an incomming dial peer configured to strip the "642" from the beginning of the called number to match the internal extension number.
002847: Aug 28 10:00:00.728: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Called Party Number i = 0x81, '642509'
Plan:ISDN, Type:Unknown
002848: Aug 28 10:00:00.740: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x8A
Exclusive, B2
002849: Aug 28 10:00:00.764: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
Progress Ind i = 0x8188 - In-band info or appropriate now available
002851: Aug 28 10:00:05.152: ISDN BR0/2/0 Q931: TX -> DISCONNECT pd = 8 callref = 0x4B
Cause i = 0x8090 - Normal call clearing
002852: Aug 28 10:00:05.308: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8 callref = 0xCB
002853: Aug 28 10:00:05.308: ISDN BR0/2/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x4B
002854: Aug 28 10:00:07.092: ISDN BR0/2/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
002855: Aug 28 10:00:07.096: ISDN BR0/2/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
002856: Aug 28 10:00:07.148: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
This is a call from my mobile to extension 509. The call was answered then i ended the call after 3 seconds.
002857: Aug 28 10:02:47.580: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Exclusive, B1
002858: Aug 28 10:02:47.596: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
002859: Aug 28 10:02:47.620: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8 callref = 0x81
fh-nwk-uc520#
002860: Aug 28 10:02:49.920: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8 callref = 0x81
Channel ID i = 0x89
Exclusive, B1
002861: Aug 28 10:02:49.980: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01
fh-nwk-uc520#
002862: Aug 28 10:02:49.980: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
fh-nwk-uc520#
002863: Aug 28 10:02:53.532: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Progress Ind i = 0x8288 - In-band info or appropriate now available
002864: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to N/A N/A
002865: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to N/A N/A
002866: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to N/A N/A
002867: Aug 28 10:02:53.532: %ISDN-6-CONNECT: Interface BRI0/2/1:1 is now connected to N/A N/A
002868: Aug 28 10:02:53.532: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1 disconnected from unknown , call lasted 3 seconds
fh-nwk-uc520#
002869: Aug 28 10:02:53.560: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8 callref = 0x81
002870: Aug 28 10:02:53.604: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x01
08-28-2009 02:05 AM
08-28-2009 02:19 AM
Thank you for your time, glad im not going mad!
08-28-2009 02:22 AM
You're welcome, please remember to rate useful posts with the scrollbox below.
