08-28-2009 12:57 AM - edited 03-06-2019 07:28 AM
I have an issue where I can only get 1 ssh session to a 2960 switch. Are there any known restrictions, is this a bug or am I missing something.
The switch is a WS-C2960-24-S running 12.2(44)SE6 C2960-LANLITEK9-M
Solved! Go to Solution.
08-28-2009 02:41 AM
Don't know any restrictions , you should be able to have up 15 sessions I think . Check the config and make sure someone did not configure vty session 1 for ssh transport and not the rest of the sessions. If not maybe you can post the config minus any addressing.
08-28-2009 02:41 AM
08-28-2009 02:59 AM
Got it in one!!!!
The config on the lines was
line con 0
login local
line vty 0
password 7 1501020114262E
login local
line vty 1 4
login
line vty 5 15
password 7 01000F094B0703
login
cheers
08-28-2009 02:56 AM
Hi Mark,
I am not aware of any similar limitations (which of course does not mean that they don't exist).
Have you configured multiple VTY lines for ssh access? Is the "ip ssh maxstartups" configured? How does it precisely look like when you try to create a second SSH connection to that switch?
Best regards,
Peter
