andrei.goncalves Fri, 08/28/2009 - 04:37
This notification is done by the SRST router...
Once the link is down, Unity will not be able to reach the ip phone
Andrei.
Rob Huffman Fri, 08/28/2009 - 05:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rich,
Just to add a note to the tips from my friend Andrei (+5 points Andrei). You will probably find this doc interesting;
Integrating Cisco Unity with Cisco Unified CME-as-SRST
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity/configuration/guide/cme_srst.pdf
Hope this helps!
Rob
andrei.goncalves Fri, 08/28/2009 - 05:23
Hi Rob,
I took a look in your doc...
In it, the Unity is in the remote site... is it possible to have the Unity in the main office and do the same ?
I'm thinking of this because I could have the Unified Messaging with MSExchange in the main office..
when the link comes up, I could check the voicemail in the MSOutlook..
Thanks.
Andrei.
richb1971 Fri, 08/28/2009 - 05:38
Hi Rob/Andrei,
Thanks for doc Rob. My situation is same as Andrei-Unity is on main site. I know I can configure phones to dial Unitys full external number but how does Unity notify remote site phones of a message when SRST mode? Is it possible?
Rich
Rob Huffman Fri, 08/28/2009 - 06:31
  • Hall of Fame,
    Founding Member
Hey Rich,
I'm very sorry I completely mis-read your original question :(
Note: Message waiting indicator (MWI) integration is not supported for PSTN access to voice-mail systems at central locations.
http://www.cisco.com/univercd/cc/td/doc/product/voice/srst/srst40/srst40ad/srs_mail.htm
Hope this helps!
Rob
andrei.goncalves Fri, 08/28/2009 - 06:39
How about using a Unity Express in the router... during the SRST mode, Unity Express could receive the calls, store messages and I think MWI is supported...
Is it possible ?
Thanks.
Andrei.
richb1971 Fri, 08/28/2009 - 06:45
Thought so Rob :( Thanks for confirmation.
CUE:
I believe so but how would you retrieve messages if WAN came back up? Does CUE push messages to Unity when network is restored?
Rich
