help with cluster config
Aug 28th, 2009
I need to remove 2 switches from a cluster group. I haven't done it before, and really don't understand what I need to do to remove it. Can anyone tell me what I'm looking for and how to tell the master and how to remove them. Also, it appears all of the switches have the same IP, which I assume is because of this cluster. Is that correct? Thanks,
Tyler
