IP accounting between 2 sites linked by Metro Ethernet
Hi Folks,
I need a little help. I have 2 sites that are connected by a metro ethernet using a 3560 & 3750. We experience a congestion, I tried to run ipaccounting on the interface vlan that links the site.
I was able to apply it on the 3750G but when I do show ip accouting it doesn't give me anything. After googling it appears that ipaccounting if not supported on the switch.
Is the anyther way for me to look at the top tem talkers?
Thank you in advanced I appreciate it.
JP
Overall Rating: 3 (1 ratings)
Edison Ortiz Fri, 08/28/2009 - 06:56
  • Hall of Fame,
    Founding Member
There isn't any IOS tool to provide this kind of information on the 3560 and 3750 switches. You will need a 3rd party tool to query SNMP on the switch.
