DHCP Snooping on multiple switches
Aug 28th, 2009
I'd like to configure dhcp snooping on a multiple switch environment (almost all 6500s), but I have some concerns on trunking ports.
1) not-so-simple question:
I have this layout
- dhcp server connecting to port 1 of switch 1; access vlan on vlan 1
- dhcp client connecting to port 2 of switch 2; access vlan on vlan 2
switch 1 and 2 are connected via a trunk port (port 3 on both).
L3 for both vlan 1 and 2 is configured on switch 1.
Should I configure port 3 of switch 2 as a trusted port?
TIA
Ivan
Giuseppe Larosa Fri, 08/28/2009 - 07:05
Hello Ivan,
yes otherwise legitimate traffic could be dropped.
DHCP snooping looks at the source ip address and you are likely to receive traffic with arbitrary source ip address on this port to the default gateway coming from all other possible vlans/subnets or even from internet
Hope to help
Giuseppe
