Disable stackwise - 3750
Aug 28th, 2009
Can someone please help me disable the stackwise config in a 3750 switch. I have removed the switch from a stackwise configuration and need it as a standalone.
When I run the command...
no switch [#] provision
...I get the error...
%IDBs can not be removed when switch is active.
I see some documentation that mentioned renumbering the switch. However, once I renumber it I get the same error.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 1 provision ws-c3750-48p
I am starting to wonder if it is even possible to remove the default switch 1 config when you have stackwise ports??? Any ideas? Thanks!!!
nsn-amagruder Fri, 08/28/2009 - 10:41
I don't have one in front of me to confirm, but I believe this is default config. Do a show switch and if only one switch exist, you can't remove it.
If you do a switch 2 provision (model), then do a show run, you will be able to provision the ports that don't exist until the switch is phyically connected.
hope this helps,
Aaron Magruder
NonStop Networks, LLC
