Any way to test TCP port from IOS?
Aug 28th, 2009
Folks, from a Windows PC I can do "telnet IP 80" in order to test TCP port status on target host.
Any similar command in IOS?
Jon Marshall Fri, 08/28/2009 - 08:04
router# telnet 80
if you do
router# telnet ?
then you will see all possible ports you can telnet to.
news2010a Fri, 08/28/2009 - 08:26
Sorry for the stupid question. I did the below and concluded too quickly that it did not work. I turned out that instead of saying the port was not open, the IOSgave me a message which I thought it was ignoring my command.
2600#telnet 80
Trying, 80 ...
% Destination unreachable; gateway or host down
Sending 5, 100-byte ICMP Echos to, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
news2010a Fri, 08/28/2009 - 11:43
It is; but it turned out that I found ACL's blocking the traffic to the webserver. Hence the output I did not undestand initially from the IOS command.
