Inventory import from file
Aug 28th, 2009
I have just installed a LMS3.0 on Solaris 10 and trying to import inventory in a csv format. (I exported inventory file from LMS2.6) When I do this I get the error
Import from file failed.
Reason: Invalid file format.
The file name is inv_export.csv.
Can anyone tell me what I could be doing wrong?
Joe Clarke Fri, 08/28/2009 - 08:46
Chances are you left out the important header fields in the file. Can you post the file?
nawas Fri, 08/28/2009 - 11:33
I shrinked the column while I was updating the file, could this have corrupted the file? What is the best practice to handle the export/import of the file.
Joe Clarke Fri, 08/28/2009 - 11:36
Export the file from the source LMS server, then transfer it as-is to the destination server, and import it. While modifying the data is possible, and modifications to the special header rows at the top of the file will render the file useless.
