CUCM 7.1.2 - Call-Forward No Answer Internal and External
Aug 28th, 2009
I'am trying to call forward to my main AA from a one line 7911 phone when there is no answer. However when the ring duration runs out if sends it to unity and says there is no mailbox, which there isn't. When I set call forward all to the main AA it works. Does this have to do with the default behavior of call-forward? Is there any work around to this? Thanks
Jason
Jaime Valencia Fri, 08/28/2009 - 08:34
  • Cisco Employee,
  • Hall of Fame,
    2011
Default is original called number is used to determine mailbox, if 7911 line has no VM it's expected.
You would need to configure forward routing rules in Unity to catch the call
java
if this helps, please rate
