Qos Verification on 6500
nedk12345
Is there a command to verify the QOS markings and trust settings on a 6500? I am trying to verify if packets are being marked based on the trust settings. There is no external sniffer. Thanks
Edison Ortiz
You can capture this information with Netflow enabled globally in the switch and on the interfaces, then with the command show mls ip detail
Router# show mls ip detail
IP Destination IP Source Vlan Xtag L3-protocol Encapsulation
RW-Vlan RW-MACSource RW-MACDestination Bytes Packets Age
Last Seen QoS Police Count Threshold Leak Drop Bucket
Use-Tbl Use-Enble
The TOS information will be shown in the output.
HTH,
__
Edison.
Try this command "show mls qos ip" this will show policy-map/class-map attached and set/trust hits on each class-map. You can also just view an individual interface by using "show mls qos ip interface"
ex. show mls qos ip vlan 50
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
