Cisco 1310 used as Bridge: Option for integration to WLC or WCS
Aug 28th, 2009
What is the best management option for the Cisco 1310 being used as an Autonomous Bridge (pairs: Root and Non-Root). We want to manage and have some reporting back into the WCS.
Lucien Avramov Mon, 08/31/2009 - 01:12
WCS 6.0 configuration guide says that only AP1130, 1200, 1240, 1310
Bridge are supported.
The autonomous to lightweight migration support feature provides a
common application (WCS) from
which you can perform basic monitoring of autonomous access points along
with current lightweight
access points. The following autonomous access points are supported:
* Cisco Aironet 1130 Access Point
* Cisco Aironet 1200 Access Point
* Cisco Aironet 1240 Access Point
* Cisco Aironet 1310 Bridge
Mike Lydick Mon, 08/31/2009 - 05:07
I guess its not clear on what bridging features may be lost if converted to LWAP. We have Basic Root/Non-Root setup. Is it best to add toe WCS and loose detailed control of the AP or can we convert to LWAP and still support bridge mode.
Lucien Avramov Mon, 08/31/2009 - 11:00
You are correct, if you convert to LWAPP you will losse the bridge mode feature. You should then keep it as autonomous and add it to WCS, but the monitoring features will not be as complete as if it's running LWAPP.
Mike Lydick Mon, 08/31/2009 - 12:18
Thanks.I was thinking that was the case but wanted the second opinion.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
