VPN client on inside network to outside network
Aug 28th, 2009
Hi all,
I have a case that some users on inside network need to access a partner server through vpn client connection (remote access).
We created the rules to permit the udp ports 4500 500, but the connection dosen't work.
Somebody know, how can I fix this?
Is possible to permit the vpn protocols through the Modular Policy Framework?
Overall Rating: 5 (1 ratings)
Roman Rodichev Fri, 08/28/2009 - 19:03
  • Gold, 750 points or more
how is VPN client configured? IPSec, IPSec over UDP or IPSec over TCP? If using pure IPSec, try configuring "inspect ipsec-pass-thru" under "class inspection_default" in your service policy.
