Help needed: SRW224G4P password recovery
I need help with password recovery on SRW224G4P. I couldn't get into the MENU by press ESC to interrupt the normal boot process. I tried many many times, no luck at all.
Below is what I see during boot up process:
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
Done All Pass.
------------------ DONE ---------------------
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
Runtime 1.0.2
Pass
root init done
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
stacking DB: unit = 0, module type = 0
Finish Set Transition mode ...
Enter Transition mode ...
Finish Transition mode ...
Enter Master mode ...
Load certificate files : Starting
Load certificate files : Finished
Finish Master mode ...
Performing startup provision ...
CLI enter main (PROVISION)
Notify provision complete
CLI provision has been completed
Provision Complete ...
Finish Provision Complete ...
XFER: End of config sync.
Please press <Enter> to start Menu session!
Please help, let me know where I should press ESC or any other key....
Overall Rating: 1 (1 ratings)
chrcoope Mon, 08/31/2009 - 06:26
Use this procedure. I tested it in my lab with your model switch and it worked here.
Christopher
c.alperin Thu, 06/24/2010 - 08:33
Ctrl+U should make it on the boot process, and then reset to default configuration
Ganesh Hariharan Mon, 06/28/2010 - 06:31
Diagnostic 1.0.1
User Mode
Done All Pass.
Runtime 1.0.2
Pass
root init done
In order for you to reset the SRW224G4P you need to use a Data cable and use the console port of the switch. Once you are on the Console screen you could do a hardware reset.
Check out the below link for more information
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=16615&p_created=1212523507&p_sid=6PuaAz3k&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OTA2LDkwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl82PTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZWNvdmVyIHRoZSBwYXNzd29yZCBvZiBteSBzd2l0Y2ggU1JXMjI0RzRQ&p_li=&p_topview=1
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Related Content
