AP1522 - how to connect MAP to RAP via wireless
Aug 29th, 2009
I have two 1522 APs and able to associate to WLC4402 successfully via wire but cannot wireless communication from one of AP1522 which changed the role to MAP and disconnect wire.
Advise please the configuration steps or CCO URL.
Thanks in advance,
cjrchoi11 Mon, 08/31/2009 - 05:45
I cannot figure out from the URL. I'm beginner the 1522 MESH configuraiton and what I need to know is,
1. I have no problem to configure RAP since it's wire attached and register to WLC automatically by adding MAC@
2. how the MAP initial configure? I can attach the MAP to WLC via wire and able to change the role to MAP but it cannot communication with RAP when move the MAP to wireless. I'm stuck in here since I don't know how to initial configure the MAP.
Advise please,
dlawson001 Wed, 09/30/2009 - 07:17
You want to bridge the two 1522's wirelessly? What code are you running?
